Nitro N50-656-Help power cord or Power Supply Unit that came not working properly.
Moustafa
Moustafa Member Posts: 6 New User
edited February 7 in Nitro Gaming
So, I got my nitro n50-656 at staples with a warranty, everything works fine with it except the power supply/cord makes a weird electric noise. Also 1 move of the cord and it shuts off i am not sure if it's the PSU outlet or the cord. I am wondering if i should just go to staples for help.
[Edited the thread to add model name and issue detail to the title]
  • Sharanji
    Sharanji ACE Posts: 5,252 Pathfinder
    edited February 7 Answer ✓
    Hi @Moustafa
     Given the symptoms you described, it sounds like there might be a problem with either the power supply unit (PSU) or the power cord. Here are a few steps you can take:
    Inspect the Power Cord: Check the power cord for any visible damage or wear. If the cord is damaged, replacing it might resolve the issue.
    Check the PSU Connection: Ensure that the power cord is securely connected to the PSU and the wall outlet. A loose connection can cause the system to shut off when the cord is moved.
    Listen for Unusual Noises: The electric noise you mentioned could indicate a problem with the PSU. If the noise persists, it might be a sign that the PSU needs to be replaced.
    Since you have a warranty and purchased the computer from Staples, I recommend reaching out to Staples for assistance. They can help diagnose the issue and provide a solution, whether it's replacing the power cord or the PSU.
    I hope this helps!  If this was useful, please hit 'Yes' or 'Like'! Thanks! 😊
  • Sharanji
    Hi @Moustafa
