Nitro AN515-57-Battery problem-The led shows the battery is full, but the system shows 0%.
TariAttila
TariAttila Member Posts: 2 New User
edited December 2024 in Nitro Gaming
Hello guys! I can’t fix my problem with the battery. How is that possible? The led shows thr battery is full but the system shows 0%
[Edited the thread to add model name and issue detail to the title]
    Puraw ACE, Member Posts: 14,260 Trailblazer
    This model is 3½ years old and the battery may be depleted also that battery does not support Windows11 Modern Standby, try to reset the system first and if that does not work replace the battery:
    Power drain + CMOS reset: Open the back of the laptop and disconnect the battery cable from the motherboard. Locate the CMOS module under the main battery (with 2 twisted wires Red and Black, see picture) and remove the coin battery. Shorten the +/- contacts (terminals) inside the CMOS capsule for 2 seconds with a bended paperclip and put the coin battery back with the + sign facing up, close the CMOS capsule. Next, press the Power Button on the keyboard for 10-15 seconds after that remove the 2 RAM modules, clean the contacts and replace firmly in the 2 slots (if you have any good RAM modules you can replace the old modules), reconnect the battery cable to the motherboard. Close the laptop, plug-in the adapter and try to charge to 100%, boot to Windows and check if the battery meter on the taskbar reads 100%, if not the battery is dead or there is a power rail problem, and then you have to take the laptop to Acer Services in your country for checking.
  • AnhEZ28
    AnhEZ28 ACE, Member Posts: 4,502 Pathfinder
    @TariAttila
    What is the model of the Nitro 5?
    Open command promt and paste this command:
    powercfg /batteryreport /output "C:\battery_report.html"
    Open the file and post the screenshot here.
  • TariAttila
    Nitro AN515-57
