Replacement Parts for Predator x34 GS (X34 GSbmiipphuzx)
phil1c
phil1c Member Posts: 1 New User
My Predator X34 GS has started flickering to black at indeterminate intervals. Any suggestions on troubleshooting and on where I can order replacement parts?
    edited December 2024
    Intermittent display glitches are about the hardest thing to diagnose on a monitor. First step is always to check the cables, since a loose cable or one that is breaking down internally can cause that type of symptom. If you get the issue with a different, known good, cable then the next step is to try and check the power supply. Your power adapter is described as:
    AC ADAPTER
    25.TNCM5.001
    ADAPTER 180W 9.23A 19.5V 5.5*2.5*L11MM 180 1800MM
    So, 19.5V with a 5.5mm barrel connector. You might be able to test with a smaller supply than the 180W that's standard, but for a comprehensive test you really need one that big. If the power supply is good and there is no physical issues detectable where it plugs into the back of the monitor we're looking at going inside, and testing there is likely too specialized for here. Best at that point to find a qualified technician and let them do the testing to see if the issue is with the main board, internal cabling or the display itself…
