Red color displayed as pink on some parts of websites on Acer Aspire A315-59-35ND. How to fix?
knorde
knorde Member Posts: 3 New User
edited December 25 in Aspire Laptops
My question:
I have had this laptop for a few days now.
Works perfectly, only now I notice that on some parts of websites the color red is displayed as pink.
For example on the tweakers.net site you see the red bar at the top of this laptop pink.
The screen is not broken because when I paste the color red in paint it is really red.
See on the left the laptop where this problem occurs.
On the right the laptop where it is good.
Click for image
I have had this problem before with a laptop, and also solved it then but I don't remember how. That was with another laptop.
Relevant software and hardware that I use:
Acer Aspire 3 A315-59-35ND model no N22C6
Intel UHD Graphics video card
What I have already found or tried:
Hardware Acceleration off in the browser.
Installed news site drivers.
Tested in Chrome and Edge.
Greets Kees
  • brummyfan2
    brummyfan2 ACE Posts: 28,595 Trailblazer
    Hi,
    I don't think there's any problem, the panel in your laptop has more blue light effect than the other laptop, must be a TN Innolux panel, they are of low quality.
  • brummyfan2
    Hi,
    Your laptop should have one of these panels, it might be a Innolux panel shown in the list, go to Device Manager, expand Monitors and right click Integrated monitor, select Properties, move to Details tab, select Hardware IDs like in my picture and show me the number shown in Value window, I can tell which panel you have in your laptop.
  • knorde
    edited 12:58AM
    Thanks for the answer.
    This is the info:
    MONITOR\BOE07CB
  • knorde
    The funny thing is that besides the difference of red also in the forum part the left laptop shows blue.See picture:
    Click for image.
    What I also notice is that the left laptop has 6 BIT for the graphics card and the right laptop has 8 BIT. I can't adjust this anywhere (and I don't know if this is normal or not and if that's where the problem lies).
