Predator PO5-625s PROBLEM SOLVED - MUST READ. when the FAN and tempature issue
Zenus
Zenus Member Posts: 1 New User
edited August 2024 in Predator Desktops
Hey guy!
I bought the
Predator PO5-625s
two years ago and it's only been problems with it. I have now found the solution for all of you i think.
Go in to the WINDOWS-X and down to the storage/disk unit and then you DEACITVATE the Toshiba unit and when the FAN and tempature issue is good and the computer is really good after that!
(Maybe you need to restart aswell)
Hope it works for you!
Best Regards
Zenus
    edited August 2024
    They shipped a number of different drives in the PO5-625s models, in addition to the Toshiba, in a couple of different sizes, they used Seagates for HDDs and Samsung, Kingston and WD for SSDs, also in multiple sizes. Which Toshiba do you have? Does it have the current firmware installed?
