Need help finding a monitor stand for XG270SU monitor
Diamondaircraftguy
Diamondaircraftguy Member Posts: 2 New User
edited May 2024 in Monitors
I have an XG270SU monitor and I can’t find a stand for it I got it used and it came with a wall mount but I can’t use a wall mount
  • Diamondaircraftguy
    this is the front
    billsey ACE Posts: 36,182 Trailblazer
    I don't see a reference for an SU model, but do see an HU. The HU shows this:
    Unfortunately you'll likely find that the stands are only available on the secondary market as part of the whole monitor. Maybe get creative with something that sort of fits along with a bunch of epoxy. :)
