GPU Problem or Power Option problem "Maximum Performance". The fix is to disable and enable.
Arufaze
Arufaze Member Posts: 2 New User
edited June 2023 in Nitro Gaming
I am having a problem where my GPU is only using battery power even when plugged in and the power options is set on "Maximum Performance". The fix is to disable and enable the gpu everytime I open the laptop. It gets annoying since you have to do this everytime
