Charging and battery issues- connectivity issues when charging.
JVLIAN
JVLIAN Member Posts: 1 New User
edited March 2023 in Nitro Gaming
So, I've started having connectivity issues when charging. The connection to the power sourse seems to go on and off, and it causes lag. Then last night suddenly, the battery and the charging cable not longer connect at all UNLESS i hold the cable at a wierd angle. I have switched cables, I have changed out the battery, but no bueno. I have tried my best to clean the port but as far as I can tell there's no blockage or anything.
WHAT IS THE ISSUE? I've been trying to fix this for week and it keeps just getting worse.
TY
  • Hi! What is the exact model? Example: AN515-55-5890.
