Acer sp513-54n battery problem if there is a replacement battery or some other method to find out
xrx
xrx Member Posts: 3 New User
edited January 2023 in Swift and Spin Series
Hello, i have the following notebook for a couple of year now.
Battery life was never as advertised, however it has reached a point where it will completely loose it's power if closed or at sleep.
(for example overnight).
During normal use, it can still last a couple of hours.
So i wonder if there is a replacement battery or some other method to find out what's wrong.
cheers
Greg
Device name LAPTOP-GLRUSE6K
Processor Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz  1.50 GHz
Installed RAM 16.0 GB (15.8 GB usable)
Device ID 7C041A20-E14B-4686-BACD-2B14D2707E98
Product ID 00325-96697-33142-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch Pen and touch support with 10 touch points
  • Jack22
    Jack22 ACE Posts: 4,610 Pathfinder
    @xrx
    Go to device manager and uninstall the battery driver and restart the laptop. check the below pic
  • xrx
    edited January 2023
    It seems to work so far, thanks!
    However the battery life generally feels a bit limited.
    Any idea if i can replace the battery. I read somewhere that in some models it is not possible.
    How can i find that out?
    cheers
  • wascas
    wascas Member Posts: 1,243 Overclocked Contributor WiFi Icon
    edited January 2023
    Yes, you can replace the battery. This video will help you.
    Acer Spin 5 (SP513-54N) - disassembly and upgrade options
    Also check the battery wear. To do that, download hwinfo and have a look at the wear level of your battery at the left side of the smart battery menu.
  • xrx
    Thanks Wascas, it says 41% wear so i guess i should change it.
    thanks!
