Can someone help me fix my sound issue (Right speaker sound very low despite settings showing max)?
TARDIS2008
TARDIS2008 Member Posts: 4 New User
Hi,
One of my laptop internal speakers audio (the right speaker) is barely audible. I have restarted the computer. Checked the properties and settings (shows both left and right speakers at max, balance is equal) but yet there is hardly and sound out of it. When I play the sound test the left speaker is clearly audible but the right speaker is extremely low. I am hoping that someone can aid me in steps I can take to fix the issue. Please keep in mind I am pretty naive on computer and will need some step by step directions. Thanks in advance. My computer is a Acer Nitro AN517-55
Kind Regards,
Rich
  • @TARDIS2008
    Try windows x
    Go to device manager - Go to sound video and game controllers. Expand it
    Uninstall the sound driver from device manager. Please uninstall all the items below the sound video and game controllers. Restart the computer. It should work fine..
    If it is still not working
    Dont restart the computer.
    Go to support.acer.com
    chose your country
    type snid or chose your model
    go to drivers
    Install the sound driver
    It will work fine.
    I am not an ACER employee
                                         ★★ WILLIAM - MRK ★★
  • TARDIS2008
    Thank you for your quick response. I tried both options but unfortunately my right computer speaker still is barely audible.
  • @TARDIS2008
    Please try to use an headset or external speakers and check . If the headset and external speakers are working fine then it is a hardware issue on your laptop.
                                         ★★ WILLIAM - MRK ★★
  • TARDIS2008
    My wireless headphones work fine. So that means it is a hardware issue? Ugh. I have only had the computer since Thursday. Well, I guess I can still return it/exchange it.
  • @TARDIS2008
    Let us not come to any conclusion right now.
    It looks like a hardware issue.
    If it is still not working then we have to do a refresh and reset
    click on start - settings - update and security - recovery - reset this pc - get started
    or
    on start - type here to search - type reset this pc - click on reset this pc on the top - click on get started
    It will show you keep my files and remove everything
    chose keep my files
    chose the account - type the password - click on local reinstall - click on reset
    It will be in progress..
    login to computer and start using the computer.
    chose remove everything
    click on local reinstall - just remove my files - click on reset
    Note:
    If you do refresh ( keep my files ) - all your personal files like pictures, music , documents , videos will still be intact.  Only the applications will be lost
    If you do reset ( remove everything ) - you are doing a factory default.  It will become like a day one computer.  It will wipe out everything and take your computer to day one like a new computer.
    You can also do the recovery in an alternative way..
    There are two alt keys on the keyboard. If you look at the bottom row of keyboard you can see the one on the left side of space bar and the other on the right side of space bar. The alt key on the right side will be looking like alt, alt gr or alt car. Turn off the computer. Hold the alt key on the left and tap f10 continuously.  It will go to repair mode. It will show you chose an option, continue, troubleshoot.  If it is not going to repair mode, turn off the computer. Turn on the computer. Hold the right alt key ( alt gr or alt car or alt ) and then tap f10 continuously. It will go to chose an option continue and troubleshoot..
    Go to troubleshoot - click on reset this pc
    click on keep my files ( only applications will be lost )  chose your account and type your password  - click on local reinstall - click on reset
    If the keep my files option is not working
    Go to troubleshoot - click on reset this pc – click on remove everything – click on local reinstall – just remove my files – click on reset
    It will reinstall windows.
    If the just remove my files is not working..
    Go to troubleshoot - click on reset this pc – click on remove everything – click on local reinstall – Fully clean the drive – click on reset
    Note: You can also go to chose an option , continue , troubleshoot by holding the alt key + tapping f10 or alt gr + tapping f10 on the keyboard while turning on the computer.  Once you see the troubleshoot option, you can stop tapping the f10 and stop holding the alt key.  Then you can try the keep my files and remove everything ( just remove by files and fully clean the drive ) by following the steps which was mentioned above.
    Even after reinstalling windows if you are facing the same issue then it is a hardware issue.
                                         ★★ WILLIAM - MRK ★★
  • @TARDIS2008
    If it is still not working..
    If your laptop is in warranty you can contact the warranty dept.   Go to the website support.acer.com - chose your country.  On the new page - scroll down - click on "contact support". Scroll down. You can find the phone no to contact the warranty dept.
    If it is out of warranty, please contact local store or
    Go to the website support.acer.com - chose your country.  On the new page - scroll down - Click on "Repair My Acer" - Request to have your Acer product repaired.  There will be charges for repair.
    Additional info to contact Acer Store: Please visit the website - support.acer.com - chose your country - click on shop.  You can buy desktop, laptop, monitor and accessories. Alternatively, on the top right corner you can find the phone no to contact Acer store.  For the parts which are not available on Acer store, you have to contact local store.
                                         ★★ WILLIAM - MRK ★★
  • TARDIS2008
    It did the reset and it didn't fix the issue. The left speaker is loud and clear and the right one sounds as if the volume is turned way down on it. Ugh. I purchased it through Bestbuy. It is within the return window plus I took the extended warranty. Looks a trip to best buy will be in order.
    Thank you for taking so much time to try and correct the issue. It is too bad really. I haven't even had the computer a week. :-/
