Acer Nitro 5 AN515-45 replacement fan parts: which are compatible with what?
BillyBob2271
BillyBob2271 Member Posts: 14
edited December 2022 in Nitro Gaming
I have an Acer Nitro 5 and its fans are beginning to sound funny (seems like fan failure, no amount of dust cleaning fixed it). I was thinking of getting some replacements, just in case it gets worse and maybe a deep dust clean isn't enough to fix it, i was wondering: which fans for which system are compatible with my laptop? I have an AN515-45 btw, but i've noticed most listings are for all sorts of models such as the -51, -53 etc...
I remember watching a video where someone replaced the fans (Nitro 5) with one from the wrong laptop, and it seemed to work for the most part although apparently the fans were overall thinner, so they had a bit more clearance. this would still probably work, right? I see many listings for the other laptop model numbers and ideally id like to get the exact same but it'd be nice to know if there is some kind of compatibility guide?
