Model: Acer Nitro 5 AN515-45
Battery light and Power light keeps blinking when turned on. Battery does not charge when plugged in while laptop is turned on. Is able to charge when laptop is switched off.
Things tried:
1. Uninstalled the battery driver and restarted
2. Switched off USB charging from Acer Quick Access
3. Battery reset switch absent, and battery is internal, so removed the charger, pressed the power key for 5-10 secs until the laptop turned off, and then waited 15 mins and plugged the charger back in and waited for the laptop to recharge. Booted up after 2 hours since I got impatient that the battery full indicator wasn't coming, but the problem still stays.
Clearly not a battery issue or a charger issue since it is charging when the laptop is switched off. What I can do or redo to resolve this?
