Not working on battery - Tried replacing battery still same
Ck007
Ck007 Member Posts: 6 New User
edited August 2022 in Predator Laptops
After not using for 2 days laptop stopped working on battery it works when plugged in.
Tried visiting nearest acer service center they replaced batter and charging IC still it has same issue now service center is saying there is nothing more to do from there side and if it was on warranty they would have replaced the motherboard
The laptop is 1 year and 2 month old so the warranty has expired any solution which can be tried on this particular issue .
  • ragsak28
    ragsak28 Ally Posts: 677
    Hi @Ck007
    You can try to reinstall the battery drivers to check if that makes any difference.
    NOTE: Make sure to reboot the laptop after uninstalling the driver to reinstall it back.
    Hope it will help you in some way.
