Travelmate 253-M-32342G Power light flashes blue 5 times but will not power up.
Gum
Gum Member Posts: 3 New User
Laptop has been standing and not used for several months.
Switched it on screen said something like Battery very low Locking and screen went off.
Charge unit connected alllowed time to charge but will still not power up.
Power switch pressed blue light flashes 5 times but will not power up.
Have removed battery,held power switch down for 30,15 and 20 seconds  with charger disconnected.
I cant find any battery reset pin hole.
Any advice appreciated as all was working well several months ago.
  • Gum
    UPDATE....Matter now resolved thanks.
    billsey ACE Posts: 36,285 Trailblazer
    How was it resolved? It sounds like the battery got too low...
  • Gum
    I had connected the wrong charger !
    That would do it... :) Thanks for the info.
