TDP value for i5-10500H, model ph513-15 model 2020. Power limit throttling problem.
Junpro666
Junpro666 Member Posts: 3 New User
I'm running on i5-10500H with model ph315-53 year 2020. The TDP value provided by manufacturer is only 45W. When I open the Intel XTU program, the TDP value already set to 70w and 103w for PL1 and PL2 respectively. It is higher than the default one. It that normal or will it harm my pc? Btw I suffer from power limit throttling when CPU goes above 80 °C.
  • xapim
    xapim ACE Posts: 7,240 Pathfinder
    edited October 2021
    Junpro666 i wouldnt worry about it and not use XTU for anything remove it completely its just useless intel bloatware u just need to optimize your windows properly undervolt with TS and if still needed repaste it with kryonaut or similar if youre able to without voiding your warranty and make sure the back is lifted 2/3" at all times for a proper airflow also not sure if they are locked or not but check on TS if youre able to tinker with the PL but make sure you know exactly what youre doing also check my signature you might find some more in the predator fb group :)
    https://www.userbenchmark.com/UserRun/11532543
    UserBenchmarks: Game 43%, Desk 61%, Work 40%
    CPU: Intel Core i5-7300HQ - 63.5%
    GPU: Nvidia GTX 1050-Ti (Mobile) - 41.9%
    SSD: WDC WDS200T2B0B-00YS70 2TB - 71.4%
    HDD: WD WD10SPZX-00HKTT0 1TB - 93.7%
    RAM: Kingston HyperX DDR4 2666 C15 2x16GB - 76.8%
    MBD: Acer Predator G3-572
    I'm not an Acer employee. (just here to help in the best way i can)
    If my answer fixed you issue please accept it for any other users who search for it would find it quickly thanks :)
    If you want to learn more about undervolting/optimizing windows join the Predator fb group and youtube channel:
    Owner/Admin (HOTEL HERO/Red-Sand/Opoka Opoka)
    https://www.facebook.com/groups/PredatorHelios300
    https://www.youtube.com/channel/UCNJwGUHxSJ8FKqAhnOqQuAw
    Acer support:
    https://www.acer.com/ac/en/US/content/service-contact
    http://www.acer.com/worldwide/support/
  • Junpro666
    Ok. Thank you.
