How do I fix battery problem?? Nitro 7
Braeden
Braeden Member Posts: 1 New User
edited April 2021 in Nitro Gaming
I purchased a new Acer Nitro 7 gaming laptop, and the battery didn't charge. I sent to repair, they replaced the battery/charging cable/updated BIOS, I got it back and it worked for two days, and now it is not charging again.
I Googled "Acer Nitro 7 battery not charging" and apparently this is a well know problem.
I am sincerely asking for help, I do not want to send it back to repair AGAIN, if it didn't work the first time.
Can anyone help please??
  • Is your model an715-51 or an715-52? If it is an715-51, there are some versions of the battery-related bios. Which version did you upgrade to? Have you tried to reset the battery?
  • Easwar
    Hi Braeden,
    Since you already sent it for repair service you will have a repair warranty. So it is better to contact acer tech support again to sent it for repair they may provide you a shipping label also. If it is neccessary to replace the part they will replace it.
