Replacement parts for Acer Aspire Switch Alpha 12
ecchan168
ecchan168 Member Posts: 1 New User
After I replaced a dead battery, the laptop was power up fine.
The display works fine, but found a crack line on the front glass.
It was my fault to enforce the frame for battery replacement.
Where can I order the parts? Do I need to replace the glass only or an assembly?
The laptop is Acer Aspire Switch Alpha 12, Part. No. NT.LCDAA.001 , Product Model SA5-271.
    Unfortunately that is only available as an assembly. The Acer part number is: 6M.LB9N5.001
