My Aspire E5-575 does not power on. The internal battery reset does not work ?..
jackyjoy123
jackyjoy123 Member Posts: 6
edited October 2023 in 2020 Archives
Hello,
My Aspire E5-575 does not power on. I can not remove the battery because it is internal. I tried the internal battery reset, but that has no effect.
thanks
jackyjoy
    JackE ACE Posts: 45,221 Trailblazer
    Remove the charger. Then re-do the battery pinhole reset again for at least 60 seconds. Then plug the charger back in but don't try to turn the machine on until the battery charge LED turns from steady orange to steady blue. This may take several hours or perhaps overnight. Only then try to turn it on again. Jack E/NJ
