Acer Nitro 5 max fan speed but cpu fan not working in max rpm. I already cleared fan dusts.
Subhadip7852
Subhadip7852 Member Posts: 7 New User
edited December 2023 in 2020 Archives
Look At That.
  • Does the same problem occur when restarting the battery?
    https://www.youtube.com/watch?v=NfhgnxUJoZo&list=FLVBqwtBw09_Z9tXo1Injakw&index=10&t=0s
    On some models, it is necessary to turn off the computer, disconnect the power adapter and press the power for 12 seconds.
  • Subhadip7852
    Bro,i did that same happened,bro fan sound it also different its like roaring sometime.😓
  • can you record a video of the problem and post it on youtube? Then copy and paste the link here.
  • Subhadip7852
    sure, i will do that.
  • what is the exact model? Example an515-51-75kz.
  • Subhadip7852
    Acer Nitro 5 AN515-42
  • Is your laptop still under warranty? Also, have you disassembled your laptop to check which fan is having problems?
