aspire S7 not power on charge light on power led flush every 5 sec
fyme
fyme Member Posts: 4 New User
got S7 charge light amber lit
** power LED flush every 5 sec
** screen not turn on
** remove battgery hold power bottom for one min. plug charger , no battery, can not power up
** connect battery no charger no power up
** plug in charger charger light lid , press power btm, power LED flushing every 5 sec
** can this laptop run without battery but charger only?
** if remove battery not power up, what could be the issue ?
  • fyme
    yes, I leave charge whole night and get solid blue power , screen back to work , Thanks
    billsey ACE Posts: 36,285 Trailblazer
    What is the full model number? A blinking amber light typically means the battery is a critical low level. Are you sure the charger is still working?
  • fyme
    edited June 2020
    model number: Aspire S7-391-6413   SNID : XXXXX, Charging light is solid Amber. Blue Power LED blinking every 5 sec very weak, charger measure at 19.6VDC should be fine
    Edited the content to hide sensitive information
    Acer-Samuel
    Slow blink on the blue light usually means it's in one of the sleep modes. Have you tried a long press of the power button to force a full power off, then turning it back on normally? The voltage sure looks good, and a solid amber charging light makes me think that part is working...
  • fyme
