Serious noise issues with Predator 15 G9-593 - Battery issue ?
Requiemnico
Requiemnico Member Posts: 6
Hi all,
Since a few days, when I'm using my computer with intensive usage (like playing 3D game as PUBG), I have a very disturbing crackle sound very loud coming from the right speaker level (see image attached).
I don't think it's an issue with speakers as i'm using headphone and issue only appears when my computer usage is high.
I assume this is coming from the battery as it's located close to this right speaker.
Do you know what may be the issue ? I'm thinking that my battery is close to it's end and thinking about buy a new one.
Do you know where can I get some from official sources (living in France) ? Amazon resellers seems to have some but not sure if it's an original one.
Laptop Model : Acer Predator 15 G9-593 72Y7
Thank you very much,
  • About the noise in the sound, is it similar to this?
    About the battery, have you checked its status with hwinfo64?
  • Requiemnico
    Hi Egy,
    First of all, thanks for answering, yes it's very similar. I just upload a video about my laptop :
    https://streamable.com/t6f7x5
    Do you know where this issue comes from and how to solve it ?
  • Requiemnico
    Ok, I just discover this thread and read it up to the end :
    https://community.acer.com/en/discussion/534951/acer-predator-g9-593-buzzing-noise-coming-from-speakers-under-full-load-with-video/p1
    Seems to be a known issue on my laptop model but this thread is old (so is my laptop).
    Do you know if there is a new solution about it or is the only way to return it to ACER for motherboard replacement ?
    With Covid issue, I really need my laptop as I'm working at home :/
    Thanks guys
