why isn't my GPU fan not running at max speed? model is g3-572
viru26199
viru26199 Member Posts: 3 New User
My GPU fans aren't running at max speed. Can anyone suggest a fix to this?
  • NLfaskos
    NLfaskos Member Posts: 11
    Hello viru26199,
    What is your pc model?
    You can first try to reinstall Predator Sense by using this website:
    https://www.acer.com/ac/fr/FR/content/drivers
  • viru26199
    NLfaskos said:
    Hello viru26199,
    i tried reinstalling the predator sense app but it has done nothing.
    my pc model is g3-572
  • GAMING6698
    GAMING6698 ACE Posts: 9,259 Trailblazer
    edited March 2020
    @viru26199 it may be because Fans spin to make CPU/GPU cool and to maintain temperature, gpu is idle no need to cool gpu.
    play game then check gpu fan speed,
    when dedicated gpu is running
    Click yes if your problem solved
  • andylb
    andylb ACE Posts: 3,824 Pathfinder
    Nothing wrong with your GPU fan speed or Predator sense. You have your fan setting on Max. The max GPU fan speed is about 5400 for your model, GPU’s don’t run as hot as CPU’s so it’s max is lower. I have no idea why you would want to run your fans at max when your CPU is only 66 deg and your Discrete GPU is idle. Put your fan speeds to Auto and only use max if you are experiencing temperatures above 85 deg or you will burn those fans out fast.
    I am not an ACER employee
    Thank you and have a blessed day  B)
    ★★ ACE Pathfinder 2019★★
  • viru26199
    i have previously cranked up my fan speed and the gpu fan used to run at 6122rpm. but now it doesn't. i was checking the fan speed that's why its on max speed  or else its usually on auto.
  • DeadShot
    DeadShot Member Posts: 18 Troubleshooter
    same here but except its with my nitro 5 laptop
