My NITRO 5 loses battery power while power-off. Any help??
flyraptor101
flyraptor101 Member Posts: 2 New User
edited December 2023 in 2020 Archives
Hi everyone,
I have an Acer gaming laptop AN515-52-736F that loses battery power while is power-off, because if I fully charge battery and then shutdown for over the night, when I startup again in the morning the battery is about 85%. I have anything connected to the USB ports.
Stuff that didn't work for me:
- I've disable Power-off USB Charging in Acer Quick Access app.
- I've disable 'fast startup' on Windows 10 system power options.
- My BIOS doesn't have any ErP options to enable.
Any suggestion please?? Thanks in advance
OS: Windows 10 Home version 1909
  • andylb
    andylb ACE Posts: 3,824 Pathfinder
    First of all are you shutting down properly? Do not close the lid until the laptop has entirely shutdown. Also what shutdown method are you using?
    I am not an ACER employee
    Thank you and have a blessed day  B)
    ★★ ACE Pathfinder 2019★★
  • flyraptor101
    Thanks for your response. I'm using the regular way to shutdown the computer using win10 (picture above), and also not closing the lid.
