Realtek HD Audio missing in device manager and sound, no sound output is detected!!!
XiaoBAI
XiaoBAI Member Posts: 26 Troubleshooter
I have tried to install driver given from Acer official support and Realtek, but neither works. I also have tried uninstall completely the drivers and now they are all gone! I also tried to reset the computer but also didn't work out. Any solution will be appreciate!
  • XiaoBAI
    my laptop is predator g3-572, cpu is i7-7700hq and gpu is gtx1060- 6gb ram
  • XiaoBAI
    I tried to install from legacy device but it shown cannot start and cannot be update also!
  • xapim
    xapim ACE Posts: 7,240 Pathfinder
    edited December 2019
    XiaoBAI firstly download the acer stock audio drivers for you model form the support page and try to install them if it wont work backup whatever you need create a recovery usb drive via acer care center if your recovery partition its still intact and not corrupted ( a good 16gb usb drive will do) then perform a stock recovery clean install check here select delete everything option if after this the issue its not solved its most probably hardware contact acer support and send it back if its still under warranty if out of warranty take it to a repair shop and if the sound adapter its faulty only a full mobo replacement will do at this point
    https://www.userbenchmark.com/UserRun/11532543
    UserBenchmarks: Game 43%, Desk 61%, Work 40%
    CPU: Intel Core i5-7300HQ - 63.5%
    GPU: Nvidia GTX 1050-Ti (Mobile) - 41.9%
    SSD: WDC WDS200T2B0B-00YS70 2TB - 71.4%
    HDD: WD WD10SPZX-00HKTT0 1TB - 93.7%
    RAM: Kingston HyperX DDR4 2666 C15 2x16GB - 76.8%
    MBD: Acer Predator G3-572
    I'm not an Acer employee. (just here to help in the best way i can)
    If my answer fixed you issue please accept it for any other users who search for it would find it quickly thanks :)
    If you want to learn more about undervolting/optimizing windows join the Predator fb group and youtube channel:
    Owner/Admin (HOTEL HERO/Red-Sand/Opoka Opoka)
    https://www.facebook.com/groups/PredatorHelios300
    https://www.youtube.com/channel/UCNJwGUHxSJ8FKqAhnOqQuAw
    Acer support:
    https://www.acer.com/ac/en/US/content/service-contact
    http://www.acer.com/worldwide/support/
