my laptop Nitro AN515-53 power down suddenly and can't power up again and two power lamps are off?
mohamednour
mohamednour Member Posts: 1 New User
i powered my laptop normally , power on okay after powering with 2 min , it was power off suddenly , and can't power it again , two power lamps are off even when i connect power supply , i did power reset by pinhole , no change , i check the output power from charger is 19 V ,
  • Chech this button switch:
    Apply the electrical tape for press button switch.
    Some users have also reported similar issues on other models where replacing the rtc battery solved the problem.
    Resultado de imagem para battery rtc
