Can I use Aspire E5-576g-57Z3 without battery? If I remove battery it can cause any problem or not?
ElvinAspire
ElvinAspire Member Posts: 2 New User
edited September 2023 in 2019 Archives
and  is there any performance difference between without battery and with battery
  • Du_little
    Du_little Member Posts: 301 Skilled Practitioner WiFi Icon
    Hi
    Hope the performance of the unit will not differ much while using it with battery or in AC power
    However can you please tell whether it is removable or internal battery? why do you want to remove the battery
    Hit Accept if its useful :)
  • ElvinAspire
    İt is internal battery. Why ? Because I made render and other hard and long work that i must pluged in battery .Because  my notebook should be open . And why I want to remove my battery because when notebook work hard it cause high heat the and it reduce battery life
