Do acer Nitro 5 AN515-51 and Predator Helios 300 use same fan parts ? I need to replace mine.
Tanvir09
Tanvir09 Member Posts: 4 New User
This might sound kind of stupid but I really need to know if I can use the fans of helios 300 in my Nitro 5. My fans are making rattling noise and they need to be replaced. I searched all over ebay and aliexpress (only two sites I can buy from my country) and didn't find the fans for Nitro 5. But there are plenty of Helios 300 fans available. Nitro 5 and Helios 300 fans look same shape and size as Nitro 5 fans so I was wondering if they can also be used in Nitro 5 ?
  • What is the exact model of the predator helios 300? Example g3-572-70qk! Some versions, such as g3-751, g3-572, and g3-573 share the same hardware with the an515-51 model!
  • Tanvir09
    Thanks, It's G3-571.
  • Yes, they are compatible! But note that the g3-571 model comes with the 1050, 1050ti or 1060 video cards!
  • Tanvir09
    So it should work with my 1050 ti laptop ?
  • It should work fine, since the service manual that the video card 1050ti is referring to n17p-g1, see:
    Now, have you ever tried cleaning fans to see if they solve the problem? It may just be dust accumulated!
  • Tanvir09
    That's a relief. Thank you so much.
  • Post the result here!
