H236HL Monitor parts
Grizzlyy
Grizzlyy Member Posts: 3 New User
Hello,
My monitor has had a heavy object fall onto it and the lcd has completely broken. I need the part number or a link to a replacement lcd as I cannot find it anywhere!
thanks.
  • This is the partnumber of lcd:
  • MaClane
    Good night Grizzlyy !
    Did you check if any part of the internal board or any electronic component was not affected as well?
    Atenciosamente:  J. MaClane™
    Sincerely, J. MaClane ™
  • Grizzlyy
    I take it that the ‘PANEL LM230WF3-S2E2’ is the actual part code right?
    also I have not checked for any other internal damage as of yet, but will be doing so in the morning
  • The partnumber is this one: 750GMT230W3E21N100
  • Grizzlyy
    Ah, thank you kindly! I don’t suppose anybody knows of somewhere online that would stock this also?
  • As Mr Maclane said, you should check for other problem parts!
