CPU fan speed doesn't reach max speed Helios 300 G3-571
I have a Helios 300 G3-571 laptop which I bought around August 2018 . Since a few days, I started to hear a small noise from the bottom of my laptop and on closer look, I found that one of the fans was struggling to spin. It spins for a fraction of a second and then stops immediately. I opened up the predator sense app and it shows that that the CPU fan is at 0 while the GPU fan is running at normal speed. Even on switching to max settings, the GPU fan reaches 6000 RPM while the CPU fan shows idle. However, sometimes the Predator sense app starts to show that the CPU fan is spinning as well, but it does not reach its maximum speed of 6000 now. And, I think it's starting to heat furthermore when I play games nowadays. What might be the issue with the CPU fan though? Is it directly related to the temperature as well?
