is it good to run laptop on charger power insted of battery power. if not why?
saurabhverma
saurabhverma Member Posts: 2 New User
edited April 2024 in 2018 Archives
what happen when we run laptop on charger?
Best Answers
  • Rudy21
    Rudy21 ACE Posts: 1,789 Pathfinder
    I would not recommend using the unit on battery power. Reason, inorder to use the device you would have to connect the charger all the time and due to this it creates static energy inside the device and this would cause problems.
    Problems like the comp does not turn on, Would not respond, flickering display etc.. and the worst case it could fry out the charging port connected to motherboard.
    Click on 'Yes' to accept my comment as answer
  • Commodore_1995#
    Commodore_1995# ACE Posts: 98,343 Trailblazer
    High-performance notebooks only use maximum hardware performance when configured for high-performance power options and with the power adapter plugged into the electrical outlet! I suggest that you do a mixed use, that is, when you play, let the battery charge up to 100% and then plug in the power adapter and when you use the notebook to type in word and watch videos on youtube, use the battery!
  • Rudy21
  • Commodore_1995#
  • saurabhverma
    thanks for your answer. my laptop is Acer Nitro 5 Ryzen series. Its good to know that i can run laptop on direct charger.
