I need help with fan speed and predator sense..
I own a gx 792 laptop
My predator sense is very basic version and I don't see a way to find a better version of it where some people have options for manually controlling it's speed upto even 6000 rpm.
I don't understand why a 4000 dollar laptop comes with such basic app that only lets me to tick on or off max speed which only comes to 4300 rpm (with coolbost) and it doesn't stay.
Under heavy load, it goes down to 3600 rpm and my cpu temperature spikes to 96C sometimes.
I have throttle stop app installed and thanks to it my CPU maintains 82~85 C assuming my fan speed is constant at 4300 RPM but it doesn't.
It always goes back down to 3600 RPM after 10 ~ 15 minutes then I would have to go back to main screen where nothing is going on or just turn the game off to put my Fan speed back up again
by using CoolBoost in acer quick access app.
So in short my questions are..
1. Is there a way to get a fancier version of predator sense?
2. Is there a way to force set the fan speed to be at 4300RPM or higher
Thanks in advance.
