Laptop auto shutdown issue without low battery warning when battery power is 30%.
Hi guys,
I bought this laptop with pre-installed endless linux os a month back. Later, I loaded with Linux Mint system. Since then, the laptop is shutting down without low battery warning even at 30% itself. After laptop is started with charger plugged in, the battery % was showing 0! I tried to setup low battery alert by installing tlp, battery-monitor softwares etc. but went in vain. Please do suggest whether the issue is related to Operating System or problem with battery itself. I even contacted the acer authorised service centre. They suggested that the laptop is all perfect and no option is available to set the low battery limit in the OS. Please help me in this regard.
