I need a example for parts in my computer to make it faster and better.
helgejul
helgejul Member Posts: 2 New User
edited February 2024 in 2018 Archives
I got a Gtx 1050 ti 4gb graphics card, i5 6400 processor, Acer Predator G3-710 motherboard, 64-bit windows 10.
My Cpu is 100%, gpu 80%, Ram 90% (when i play games)  My goal is to get more fps and faster computer in general.
    billsey ACE Posts: 36,311 Trailblazer
    Going to be a bit tough to bump up much without a major overhaul. The G3-710 models that came with the 6th gen CPU (as is '6'400 models) need 6th gen CPUs, so pretty much the only upgrade there is a i7-6700. The GTX 1050 ti can be upgraded a bunch, depending on how deep your pockets are, 1060, 1070, 1080 ti? How much memory do you have? That might also be an easy bump, IIRC yours supports up to the 16GB modules. Finally look at your storage, if you aren't booting and running from an SSD you can get quite a bit from that.
