Is a 12pin to 24pin atx power adapter possible with my build?
moab6
moab6 Member Posts: 3 New User
edited February 2024 in 2018 Archives
I have a FSP500-50AAGA PSU and recently upgraded to a new MOBO that only has a full 24 pin atx power connector. Can I use a 12pin to 24pin power adapter without any issues?
    billsey ACE Posts: 35,154 Trailblazer
    They should have the same signals, but the normally found adapter is just backwards from what you're talking about. They let you plug a normal 24 pin ATX connector into the 12 pin ATX motherboard. The genders will be different.
