Dear Acer
Dear Predator 17 G9 793 users.
I would like to ask you if this is normal:
When idle, at very low fan speeds, while going UP of DOWN the RPM of the right fan produces a light "whistle" sound.
When the fan passes the "whistle RPM" area then its normal.
Under full load (max fans speed) its perfectly normal. This only happens at low fan speeds.
The noise appears at around 2300RPM
Is it the CPU or GPU on the right exhaust?
Is it normal?
Do you experience a similar situation?
If
 Acer let the users tweak the fan speed, I could put it a bit higher so
that it will be above the "whistle RPM" then the problem will be solved.
Thanks for your input.
