Aspire E5-573-32JT power led blinks and shutdown after 30 seconds and no display.
AsheeshKumar
AsheeshKumar Member Posts: 4 New User
edited September 2023 in 2019 Archives
Hello,
I have an Aspire E5-573-32JT with Windows 10 Pro. I bought it last year, it was working fine till yesterday. Yesterday I spelt few drops of water on the upper side of touchpad. I quickly soaked as much as I can from a towel. But after 20 seconds, laptop went off. I quickly open the laptop and saw that there was a few drops of water under the trackpad, a drop was also on space key but no water on motherboard. I cleared all the water and turn on the laptop again. It turned on but started automatic repair then showed me advanced repair option then shut down after a few seconds. It happened three times.
Next day I put all the parts in sunlight to remove any moisture. I turn it on and it worked fine. After around 1 hour, it shut down again without any warning. I turn it on again and it worked fine again. But after a few hours it again shut down. Laptop was not heating at all and battery was around 70%.
When I tried to turn it on again, power led blinks 5times and nothing was there in the display. Although I can see that pixels were turning on in the display. I removed battery and press power button for 20 seconds then turn it on using adapter but same thing. I reseated RAM and unplugged touchpad and all other unnecessary usb cables and tried to turn it on, but power led blinks for 3 or 5 times then goes solid for 30 seconds and then shutdown. I can see that pixels of display turns on but nothing happened to display, it is all black, not the acer logo. Now when I am trying to turn it on, power led goes solid without blinking, fan and HDD rotates, pixels turn on in the display and everything shuts down after exact 30 seconds.
Any help will be appreciated.
    JackE ACE Posts: 45,219 Trailblazer
    edited May 2018 Answer ✓
    NOT WATERPROOF!!! SO YES, COULD DAMAGE THEM!!! Maybe some water-resistance but NOT waterproof!!! Due to dissimilar metals, electrochemical/electrolytic damage is also possible when components are subjected to moisture. Thus you should NOT try to rinse anything as a precautionary measure in an attempt avoid possible future problems due to the bottled water incident. Only rinse if problems actually arise. And then be very carefull try to minimize & confine any rinsing to the areas that you suspect were originally moistened by the bottled water droplets. And quickly wick away and dry any rinse moisture . Jack E/NJ
    >>>Yesterday I spelt few drops of water on the upper side of touchpad.>>>
    Bottled water? Well water? Distilled water? Seltzer water? Sea water?  Jack E/NJ
  • AsheeshKumar
    Yeah bottled/drinking water.
    Thanks
  • AsheeshKumar
    Quick update!
    I put all the parts in sunlight for one day, assemble again and try to power on the laptop, power led blinks for three times then goes solid for 30 seconds then turn off. Without RAM it was blinking one time then solid but not shutting down so I think there may be problem with RAM, I put it in another slot then something different happened. While RAM in first slot, power led was blinking (means quick turn off), while RAM in second slot, power led was not blinking, it was trying to start the laptop but then after a second it was turning off cause I could hear the sound of HDD turning off. It happened five times then suddenly display came on.
    Laptop started and worked fine. I put RAM in first sot again and power on the laptop and surprisingly it turned on.
    Now it is working  fine but I don't know how long it will last.
    Can someone tell me why it is happening?
    Thanks
    I'd guess some slight mineral (salt) residue remains after the bottled water evaporated in the sunlight. I'd also guess this residue might cause intermittent issues when the humidity rises. If it does, you might want to try gently rinsing or atomizing those areas that you think might've been exposed to the droplets with rubbing alcohol/distilled water, wicked away with absorbant tissue to remove the residues. Jack E/NJ
  • AsheeshKumar
    Thanks a lot for your time JackE.
    I have a question. Are the components of motherboard e.g. Transistors, Capacitors, Diodes, ICs, Circuit Board etc. waterproof? I mean will there be any damage to them without any power?
  • SchizoBG
    SchizoBG Member Posts: 8
    Man i feel so lucky. I spelt beer on my Acer Aspire e5-573 two times for 1 year, and the first time it was quite a lot of beer and it didnt even turn off. I turn it off offcourse but while i was whiping the beer pres 2 times power button accidently and still it was booting. Leave it for all night without trying to start it and it is working still like nothing happened. Maybe i should bring it for moisture check in service. Hope you sort it out with your notebook bro.
