Why predator sense shows fan speed as zero, it doesn't read fan speed
KiranKumar2914
KiranKumar2914 Member Posts: 1 New User
edited November 2023 in 2018 Archives
I have a predator helios 300 laptop,
 model: G3-572-58M1, my predator sense app doesn't show the fan speed, and I can't update my drivers also
  • Skelomorph
    Skelomorph ACE Posts: 463 Pioneer
    I would like some more information:
    What drivers won't update?
    Did you try updating/reinstalling Predator Sense?
    Did you try running Predator Sense in Windows 8 compatibility mode?
    Are you using a third party application to control or access the fans?
    Are temperatures low, because fans don't spin if temperatures are low?
    Skelo
    Please quote me so I get a notification of your reply!
    If I helped you, like my post and/or select my post as 'Solved'.
    Please put your laptop model in your signature so we can know what device you have.
    Product: Acer Predator Helios 300
    Model: G3-571
    "Don't cry because its over, smile because it happened."
    - Dr. Seuss
