plugged in not charging and static sound from speakers at low battery
gr_reaper_20
gr_reaper_20 Member Posts: 111 Skilled Fixer WiFi Icon
edited November 2023 in 2018 Archives
laptop is plugged in but doesn't charge while gaming but this problem occurs only when battery is low,say around 25% .As soon as the battery hits around 40%+ charge the problem resolves, even when gaming there is no problem.
Also at low battery level sometimes static sound comes out from speakers along with normal sound.
Hope that helped you.
Best Answers
  • IronFly
    IronFly ACE Posts: 18,412 Trailblazer
    Contact Acer support service, not a normal behaviour.
    I'm not an Acer employee.
  • gr_reaper_20
    thanks for the advice!
  • IronFly
  • gr_reaper_20
