acer aspire E1-531 does not turn on ,baterry led light does turn on and HDD light
agnes1
agnes1 Member Posts: 1 New User
edited August 2023 in 2018 Archives
I have an Acer aspire E1-531 when I turn it on the fan goes on for few seconds and then shuts down ,power led light (blue) does not turn on ,only battery and HDD light does turn on and the screen does not work.I also find out power jack cable is a bit burned but mother board is still fine.and led display cable is broken too.Do I need a new motherboard also?
    JackE ACE Posts: 45,220 Trailblazer
    You must first try a new video ribbon cable. Google "e1-531" and "video cable" with the quotes. Cost around $10 USD. Jack E/NJ
  • surajsharma
    surajsharma Member Posts: 1 New User
    I have an acer aspire e1 531 laptop. When I was working it suddenly get off.  After then when I start it the it was on and led light was blinking but suddenly it was off due to battery discharge. I put the AC adapter and found that no power and no led was burning. It got power problem. My charger is OK it supply 19 volt and power connector is OK  I had checked. But how can it will turn on?  Still there is no display and no led is burning. Please help me regarding this.
