m7720 blackout screen, CPU fan not working but have power led lit in motherboard. Can't switch On.
nath
nath Member Posts: 1 New User
Any help? My Acer m7720 Can't switch On, CPU fan not working but have power led lit in motherboard.
  • IronFly
    IronFly ACE Posts: 18,412 Trailblazer
    unplug power cable, open the left side of PC case, look for a round silver battery (it's under the graphic card), take off battery for about 5 minutes, check its voltage too)
    press power button twice
    then put back the battery or replace it if voltage is low (under 1.2V)
    put the power cable back and try to power your PC
    I'm not an Acer employee.
