I need help figuring out what battery will work for my ACER laptop.
ProtoflareX
ProtoflareX Member Posts: 4 New User
edited March 2023 in 2014 Archives
I need to replace the battery of my laptop, but I cannot figure which one is the correct one to purchase, so I was hoping you guys could help me figure that out.
Model number: MS2253
Aspire 5735/5735Z/5335 Series
DC Rating: 19V
Also, the battery has the code "AS07A75" on it, so I'm assuming it will need a battery with the same code to work.
That being said, which one of the batteries from this list will work with my laptop?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=AS07A75&bop=And&Order=PRICE&PageSize=30
  • Hello,
    Could you give me the first ten characters of the laptop serial number (S/N)? Only first ten.
    France
  • ProtoflareX
    Assuming I'm reading the right number, the first ten would be: 00148-105-44
  • Not this one. You'll find the S/N on the label sticked on the lower cover. Only first ten.
    France
  • ProtoflareX
    LXATL0X010 That one?
  • Yes this one.
    The part numbers of the batteries are:
    BT.00603.041BATTERY.LI-ON.6C.4K4mAH.SAN
    BT.00604.024BATTERY.LI-ON.6C.4K4mAH.SON
    BT.00605.020BATTERY.LI-ON.6C.4K4mAH.PAN
    BT.00607.019BATTERY.LI-ON.6C.4K3mAH.SIMP
    BT.00607.034BATTERY.LI-ION.6C.4400mAH.3S2P
    You'll also find the part number of your actual battery like this (example: BT.00303.026):
    BT.00303.026
    Note:
    P/N: LX.ATL0X.010
    Model: Aspire 5735-4774
    OS: Windows Vista Home Premium 32 bits
    France
  • ProtoflareX
    Just to make sure that I am 100% purchasing the right battery, can you recommend me one from the link in the first post? Smiley Tongue
    My battery code is BT00607034841
  • laurent_14
    laurent_14 ACE Posts: 10,399 Trailblazer
    Your actual battery is BT.00607.034.
    I advise you this one (Samsung) because the lifecycle of the cheaper batteries is short.
    France
  • Hello,
    I advise you this one (18+4USD).
    France
