Why does my AS5534 laptop not operate on battery power. Battery meter shows 80%?
dorislaneny
dorislaneny Member Posts: 1 New User
My computer will only operate when using the external power adapter. When it powers up the battery meter shows 80% but the message says battery not charging.
  • Blayn-Acer
    Blayn-Acer Administrator Posts: 2,355 Community Administrator
    It sounds like your battery may not be working properly. If you are in warranty, you can contact warranty support for your region. If you are outside of your warranty period, you can order replacement parts and accessories at http://store.acer.com.
