Aspire AX1301-U1302 that will not power up frequently. Power supply? What is the replacement PSU?
welkie1
welkie1 Member Posts: 1 New User
What is the model or specs for the power supply. Where do I purchase it. Is this likley the problem?
  • HK53T
    HK53T Member Posts: 767 Die Hard WiFi Icon
    Have you contacted support or your reseller?  They should be able to get you a replacement PSU if it failed.
