My V5 471PG battery charging light blinks for 3-4 times then stops then battery not charging.
taj_mechanics
taj_mechanics Member Posts: 2 New User
What maybe the problem? Is it the battery or what?
  • RevoMaxx
    RevoMaxx ACE Posts: 458 Pioneer
    It almost sounds like there is a problem with your Battery or Charging unit.. It could be that there is a short in your Charger Cord and if you unplug it form the computer and run down the length of the cord you may find any area where it became kinked and then damaged.. Also if you have a meter you could try testing the charger and see if it is working to the Specs of the charger... Shold be wrote on the unit how DC output it is. Maybe 19 to 20v DC...
    Hope this helps some
    James
  • taj_mechanics
    Hi James,
    Thanks for the info and help.
    But it seems that there no issue with the charger because I can still use my laptop while its directly connected with its charger without battery.
    Maybe its the battery itself or is there any problem with its electrical circuit inside my laptop?
    Thanks again.
