Acer TravelMate B113 LED Sleep - LED Blinking
rizkialkaf
rizkialkaf Member Posts: 2 New User
HI, i need some suggestion here
I'm using Acer TravelMate B113. Started from yesterday, when i put my laptop to sleep, the orange power LED (light bulb) is blinking quickly, about 15-16 quick blinks, break, and then repeat.
what does it mean?
it usually a normal, slow blinks before yesterday
every other thing seems normal, the sleep itself, wake, etc
Thanks
  • Performing a static discharge of the mainboard:
    1. Unplug your AC adapter and remove your battery.
    2. Press and hold down the power button for 10 seconds and then release the button.
    3. Plug in the AC adapter again, put the battery back and power on the system.
    DID THIS FIX THE PROBLEM?
  • rizkialkaf
    Thank you for your reply,
    Actually, i'm not sure. I did this method several times. But the problem still randomly shows up.
    maybe if someone knows what those blinking pattern means, we will know what is failing
  • It could be a bad power supply or a bad battery.
