Tema
Responder
ACE Pathfinder
IronFly
Envios: 2.451
Re: Acer r7 has no sound output problem.
Can you check on system services if any bluetooth service is available and if it's started and set to automatic?
windows key logo + R
type 'services.msc' (without quotes)
If i was helpful, a KUDOS is appreciate and remember to mark "Accept as Solution" if you solved your problem.
I'm not an Acer employee. :smileyhappy:
Member
Ray2
Envios: 7
[ Editado ]
Bingo! Thank you, I had attempted to set up a bluetooth headset with Dragon Naturally Speaking 13 the day before I lost sound, so I Stopped the service per your comment and deleted the headset from Dragon and sound was restored after a reboot. Question after reboot with sound working properly the Bluetooth Service is agin running in automatic should this be reste to manual or manual trigger start instead of automatic?
ACE Pathfinder
IronFly
Envios: 2.451
You can try it but i think it's needed to be automatic.
Bem Vindos
Não é um membro?   Registrar
Ajuda
Idioma:
Usuário Destacado
Convidamos todos os usuários da Comunidade a dar Kudos para nosso amigo Lucas2014. Contamos com sua colaboração. Sua participação tem sido de grande ajuda aos nossos outros usuários da Comunidade Lucas2014.
Contributor
Você sabia?
Acer Community também está disponível nos seguintes idiomas:
