During my my adding software to my Acer Switch 10 SW5-012, I ran into a sudden reboot issue. When I checked the Windows event viewer, I saw this message:
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000050 (0xbbd8efdc, 0x00000001, 0x8e280386, 0x00000000). A dump was saved in: C:\windows\MEMORY.DMP. Report Id: 012215-9687-01.
I was able to reproduce this by putting the Switch to sleep for 2 minutes and then plugging in AC power. I would have trouble with the power button in terms of waiting. Eventually, the Switch would wakeup as if it was shutdown.
I recovered with a full restore to the factory state and tried the same AC power scenario and did not encounter the bugcheck. However, when I installed the Acer update for Power Management, I was able to see the bugcheck happen again with the AC power.
I would venture that there is a bug in the new Power Management update update 7.00.8106.0.
I have installed a lot of software including BatteryBar, BatteryInfo, CrystallDiskMark, Performance Test, PCMark, Touchmousepointer, Macrium Reflect, EPM, and more. None have them have produced this bug check. Only after I install the new Power Management update do I get the bugcheck. Of course I have reverted to a saved image prior to the update.
The symptoms include unexpected reboots and the power button not responding promptly.
The Switch is the only tablet that I have used that wakes from shutdown with a simple touch of the power button. Other tablets like the Dell Venue 8 Pro, the HP Stream 7, and the Lenovo Yoga 2 10 need a press of three or more seconds to wake up from a shutdown or hibernate.
I am having no issues with the Switch 10 other than not being able to update to the Power Management update. This has been the best inexpensive Windows 8 tablet (2 in 1) that I have tried. I love the hinge!
