I require a replacement battery for Acer Extensa 5620G. Current battery is model GRAPE34, 14.8 Volt,
fj62
fj62 Member Posts: 2 New User
Capacity is 4800 mAh.
Is this correct?
Suppliers are offering GRAPE32, 10.8 Volt and 5200mAh.
Thanks in advance.fj62.
  • laurent_14
    laurent_14 ACE Posts: 10,401 Trailblazer
    Hello,
    For information, here are the part numbers of original batteries:
    Spoiler
    BT.00603.029BATTERY.LI-ION.6C.2000mAH
    BT.00603.043BATTERY.LI-ION.6C.4400mAH
    BT.00604.015BATTERY.LI-ION.6C.2000mAH
    BT.00605.014BATTERY.LI-ION.6C.2000mAH
    BT.00605.022BATTERY.LI-ON.6C.4400mAH
    BT.00605.025BATTERY.LI-ION.6C.2000mAH
    BT.00607.008BATTERY.LI-ION.6C.2000mAH
    BT.00803.022BATTERY.LI-ION.8C.4800mAH
    BT.00804.019BATTERY.LI-ION.8C.4800mAH
    BT.00805.010BATTERY.LI-ION.8C.4800mAH
    BT.00807.013BATTERY.LI-ION.8C.4800mAH
    E.g. a compatible battery.
    France
  • fj62
    HELLO laurent_14.
    Thanks for the quick reply.
    I will look for  a 14.8 volt battery with 4 cells as you have given me a part number.
    Thanks again.
