How to I get the battery charge indicator to work after installing a new battery?
Jbauer
Jbauer Member Posts: 5 New User
I have an Aspire 6530 running Vista Home Premium OS. I recently replaced the battery but now the power management applet doesn't show battery level and the indicator shows 0% remaining when I unplug the power supply even though the battery is fully charged. Is there a remedy?
    JackE ACE Posts: 45,224 Trailblazer
    Power down. Replace the new battery with the old battery. Power up with the power supply plugged in. What happens now to the battery indicator?
  • Jbauer
    Following your instructions, the battery status in the mobility center says 63% and charging, the indicator in the status bar shows the percentage, plugged in and charging.
  • Jbauer
    Does this result suggest anything to you about the new battery?
  • padgett
    padgett ACE Posts: 4,532 Pathfinder
    It is on the rong side of the bathtub curve.
    >>>It is on the [w]rong side of the bathtub curve.>>>
    Bingo! 8^)
  • Jbauer
    Even though the old battery shows a charge and time remaining shows as 20+minutes, the computer will shut down. The trouble with the new battery is that I have no way of knowing what the level of charge remaining is.
  • Jbauer
    What is the resolution to being on the <<<wrong side of the bathtub curve>>>?
    Both the old & new batteries have built-in control circuits that are ***supposed to properly communicate*** the battery's charge level to the operating system's indicator app and the laptop's charging circuits. Your old battery's built-in circuitry still seems to be partly functional. The circuitry in your new battery does NOT. Accordingly, I'd return the new battery to the vendor for a replacement.
