Aspire V5-571P not dislplaying low battery alerts (tried advanced power settings already)
mlleperenelle
mlleperenelle Member Posts: 1 New User
Hi, I have an Aspire v5-571P Touch, running Windows 8.1, and for two years it's been awesome! But recently, it's stopped displaying low battery alerts. I've tried going to the Control Panel, Power Options, and using a different power plan. I've made sure that all of the power plans' advanced power settings are as follows (after a suggestion of upping the low battery level from 10% to 20%):
  • Critical battery action: On battery: Hibernate
  • Low battery level: On battery: 20%
  • Critical battery level: On battery: 5%
  • Low battery notification: On battery: On
  • Low battery action: On battery: Do nothing (Sleep, Hibernate, and Shut Down are the other options)
  • Reserve battery level: On battery: 9%
I've read an article that suggested updating the BIOS, though there's also a red warning on that page of the Acer website;
"Upgrading your system BIOS incorrectly could harm your Acer Product. Please proceed with caution."
So I was apprehensive. If anyone has suggestions here before I attempt updating the BIOS, that would be great, thanks!
  • IronFly
    IronFly ACE Posts: 18,412 Trailblazer
    If you want to try BIOS update, be sure to have battery fully charged and the AC charger connected.
    unzip the file and run VA410218.exe, then just follow on screen instrucionts.
    the red warning it's just to warn about possible problems but nothing to worry about. Smiley Happy
    I'm not an Acer employee.
